• ¿Cómo actualizar mapas a cartografía edición 2015-2?
 #190687  por miguelidanez
Cartografía Europa RNEG MyWay Edición 2015-2
Spoiler: Mostrar
Enlaces MEGA:
https://mega.nz/#!CRwEBB4b!B-7Woyu_q3iy ... dXM4CxDjW8
https://mega.nz/#!bAQmHYCA!75g2Wr-vnuqB ... HQpX2GZdgE
https://mega.nz/#!iYBAjaSI!Ft91vY3BYezF ... olBjRTxV5Y
https://mega.nz/#!mV52jL4K!_8exbDjeGUaD ... OSVOLkMUvs
https://mega.nz/#!OYYFSRIb!PKa4HST99EKm ... kIGSdOMVB0
https://mega.nz/#!DYRhATjb!6F0cZlyRrrpi ... F9vvFER-Wo
https://mega.nz/#!vMxn1K6L!_qqNrG5hqjAi ... 9o1szjQgAg
https://mega.nz/#!mJ5GBDTS!-3XhZqR_AEGH ... MHmMWXFqfE
https://mega.nz/#!PVxDHZqK!oH0dRQhftVeD ... g8na6hou_k
https://mega.nz/#!WZhAWbpK!8bL_olkYUjE3 ... knrfxBhEF8
https://mega.nz/#!eRJwgRIT!wORuqPCTLW2Z ... HyzzQNEhjc
https://mega.nz/#!eQgD1DQA!oPoefE8K5Le3 ... FIVBHidkFU
https://mega.nz/#!zEY1mRwS!RcQe0gsOAru- ... tnztmKoFZI
https://mega.nz/#!jcBUjJCL!tvtMQhvy4HFX ... RDoFk2z07I
https://mega.nz/#!eVp1hZjD!rQnGwRjodfMv ... r_8cyjEcjk
https://mega.nz/#!jFIj0J6D!WwtfX2WBfmoi ... 6CLE_LifFQ
https://mega.nz/#!qcoVEYoB!Pnu4WR1H7SZG ... 1rEj2-qUgs
https://mega.nz/#!TZwyRDIR!simrmnE7_pcx ... EfNiDS5Ogc
https://mega.nz/#!iUojwDyS!Hs3J0n4GKxcg ... v2R_ix2E9I
https://mega.nz/#!mIxW2JQY!mPSFbyvvdkDu ... kWU7aP0IuM
https://mega.nz/#!aBZCgSSS!9U_dcL0yh_Ai ... k-y0dbYXV8
https://mega.nz/#!qYplkCSB!qPbQeyT73slL ... 903RPuW2oQ
https://mega.nz/#!7ZZF0QDJ!Lnbzp1Mt6S4U ... L6n-om6k4k
https://mega.nz/#!WU42GZhZ!Cv6Vwq1UgdeR ... G4KPKW2NXI
https://mega.nz/#!nJRmCI5A!-HAM34TArNgU ... 6Vj1o6TM3c
https://mega.nz/#!PMhWiArb!By2m1Sdpsh1n ... 2y-PnP03q0
https://mega.nz/#!rYAyiAZT!6nvBT3_cG9ZJ ... ia7fm-5Gkc
https://mega.nz/#!vZB1QZSB!rttMwy-cGnz8 ... mU-sIV-WcM
https://mega.nz/#!zEh2hQwT!ZV9R-EMN1-DU ... hLECP0ROd8
https://mega.nz/#!zQAlxYwK!FxyW43A_tvbM ... GvRudogn1c
https://mega.nz/#!LQwj3Kwa!9VZQz_QIBWlu ... 0cjXpqE9JM
https://mega.nz/#!ucQi2YpC!MBXzetzsxQ4Y ... F14G4OoVLI
Enlaces UPLOADED.TO:
http://ul.to/1c9by896
http://ul.to/qifqao14
http://ul.to/wpeybac6
http://ul.to/64r7yx0x
http://ul.to/gq4tdife
http://ul.to/ujm8rtx9
http://ul.to/4ahyvxbm
http://ul.to/j0ao32k9
http://ul.to/56qi8uy0
http://ul.to/8a2ez6qe
http://ul.to/5hlrzf1f
http://ul.to/6swws7ic
http://ul.to/ska168tr
http://ul.to/2s7u9xhw
http://ul.to/0tqtnze5
http://ul.to/9xc4uoxy
http://ul.to/evlqwqqz
http://ul.to/x784rfnj
http://ul.to/z6807vd8
http://ul.to/f3qyvjza
http://ul.to/etgh031c
http://ul.to/n3g6pd7q
http://ul.to/580963sq
http://ul.to/ovikccpn
http://ul.to/kjxpw850
http://ul.to/dowd45ft
http://ul.to/awdudnqd
http://ul.to/rvuul7di
http://ul.to/wvhztwsx
http://ul.to/aadxqzjl
http://ul.to/iwlg316u
http://ul.to/md66w7ho
Como sabéis se ha hecho una compra conjunta de los mapas 2015-2 para el navegador RNEG MyWay. Después de que todos los participantes la han descargado y previamente de haberla puesto a disposición de los participantes de ediciones anteriores , se pone ahora a disposición de todos.
Todo continua igual que los anteriores mapas, por lo que una copia "tal cual" de la tarjeta original no funcionará en versiones del navegador superiores a las 20.16. La versión que está ya modificada y comprobado el funcionamiento en todas las versiones del navegador, incluida la última versión y también más estable, la R50.03.
Os recomiendo que actualicéis el navegador a la última versión del software. Habrá alguno que no quiera complicarse, pero sigo siendo de la opinión que más vale tener lo último que tiene los posibles problemas corregidos.
El pack contiene los mapas 2015-2 (ya hubo otra versión en el primer semestre). También incluye los radares actualizados.
Instrucciones de instalación:
1) Se necesita una tarjeta de al menos 16gb, aunque es posible que en alguna tarjeta de 8gb quepan, ya que la capacidad total varia según las marcas. En cualquier caso es recomendable la de 16gb pues así la tenemos con espacio de sobra para siguientes versiones. Si la vais a comprar, mejor que sea de clase 10 que son las más rápidas, aunque una de menor velocidad funcionará igualmente, aunque es posible que notéis más tirones el desplazarse los mapas.
2) Bajar todos los ficheros de un pack. También podéis bajarlos uno a uno. Recomiendo jdownloader, pues os permitirá bajarlos todos automáticamente (siempre con las limitaciones que imponga el servidor de descarga) e incluso os los descomprime en la carpeta que le indiquéis.
3) Crear una carpeta temporal en el disco duro del ordenador y descomprimir todos los ficheros en ella (si habéis usado el jdownloader seguramente ya los tenéis descomprimidos). No hay que descomprimir todos los ficheros. Es suficiente con descomprimir el primer fichero y el descompresor automáticamente coge el resto de ficheros hasta terminar.
3) Os encontrareis una carpeta llamada "database" en esa carpeta temporal del disco duro. tenéis que copiar esa carpeta completa con todo su contenido a la tarjeta SD. Podéis hacerlos con "copia y pega" o arrastrándola con el ratón.
Os recuerdo que el problema más habitual suele ser que el navegador no reconoce la tarjeta SD. En ese caso, solo tenéis que volver a sacarla, esperar unos segundos y volverla a introducir, y la debe reconocer sin problemas. Si continua sin reconocerla, es cuestión de repetir el proceso varias veces que al final la acaba cogiendo sin problemas. Si aun no os la reconoce, también he comprobado que dejándola un par de minutos o menos, acaba reconociéndola.
Miguel Angel
 #190820  por jacintobena
Bueno parece ser que como el firmware de nuestro Myway ,dejaron de dar soporte hace + o - dos años con los mapas parece ser que también ya que para el emyway salieron a primeros de septiembre, y para Myway a fecha de hoy todavia no han salido que para mi pienso que era el día máximo de salida
 #190823  por jacintobena
a ver si tenemos suerte acaba de salir recientemente la actualización para NaviDrive 3D y NaviDrive (RT4/5) que hace unos días no estaba
 #190835  por miguelidanez
Otros años han salido por estas fecha. No creo que dejen de salir. Deben estar a punto.
 #190836  por v41arcs
Cuentem conmigo para me apuntar a la compra conjunta, si por acaso! salud: birras:
 #190837  por slipknot_villa
Si se hace como siempre contad conmigo en caso de que los moderadores lo autoricen. Si hay gente suficiente que quiera participar no tengo problema en ceder mi puesto a gente que nunca haya entrado. Estaré atento. Saludos
 #190843  por papapitufo
Si el tema llega a buen puerto, contad conmigo, como en años anteriores, y si alquien que no ha participado quiere participar, le cedo mi puesto sin problemas.
 #190846  por hiart123
Hola a todos.-Contad también conmigo.Saludos
 #190850  por angelig
contad conmigo.
 #190851  por ricardoagustinelias
Y con este que está aquí,
Un saludo a todos
  • 2
  • 25
