• Calefacción adicional programable
 #191118  por Satellite
I can answer you later, in this week. Let me find some info about this!
 #191129  por volc
It would be great if you would post some information about your installation.
I saw the tread that you have written while doing the upgrade, but unfortunately pictures can't be displayed any longer.
Have you used original parts from Citroen or maybe used aftermarket Webasto set dedicated to C5 ?
I would prefer to use Citroen original parts to have everything fitting properly - mountings, pipes, etc.
The biggest problem the I have at the moment is do I really need to use original Citroen Telestart. It is extremely expansive. It would be far cheaper to buy a Telestart directly from Webasto, but at least from what I see on the electric diagrams pinout connections do not entirely fit well.
 #191131  por Satellite
Give me some days and I will post here the wiring diagram between telestart t100 and C5. ok:
 #191193  por Almartin
volc escribió: There is still maybe one budget option possible. In Peugeot 508 there is no remote control for Webasto - all settings are being maintained via screen in instrument panel. In Citroen C5 display is a bit different, but I still want to check it. I need to check C5 instrument panel in Lexia 3, maybe control of Webasto can be added there.
Best regards,
Jacek
El cuadro de instrumentos del C5 no admite la posibilidad de visualizar o controlar la calefacción adicional programable.
 #191195  por Abelin
Creo recordar, que Satellite cambio alguna centralita.
 #191204  por volc
Hello Almartin,
Gracias. También he comprobado ayer con Lexia y no hay opción de añadir allí.
Voy a tener que conectar Telestart.
 #200143  por volc
Satellite escribió: 01 Dic 2015, 10:32 Give me some days and I will post here the wiring diagram between telestart t100 and C5. ok:
Hello Satellite,
It is some time passed since we discussed about additional heating for C5 :)
Do you still remember how you have added additional heating to your C5 ? Have you used Webasto box from C5/Peugeot 508, have you used generic Telestart or maybe dedicated to C5, how you have connected it to car wiring ? Any help is appreciated :)
 #201601  por Satellite
Hello! You need to buy the citroen receiver. The remote controller is citroen spare part or webasto controller. It's the same.
This weekend I put here the parts that you need but first, send me your VIN number. Thanks!
 #201602  por Abelin
Satellite escribió: 17 Ene 2018, 23:41 Hello! You need to buy the citroen receiver. The remote controller is citroen spare part or webasto controller. It's the same.
Hola Satellite
Procura el poner las fotos en "chevronazos", si pones como las anteriores al cabo de poco tiempo no se verán.
viewtopic.php?f=3&t=16855#p198278
Esta es otra forma
viewtopic.php?f=47&t=14029
 #213161  por frangijon
tengo un pdf de como se monta una calefacción webasto para los C5 quien sabe del tema para poder subirlo aqui o compartirlo
  • 7
  • 8
  • 9
  • 10
  • 11
