alguna opinión sobre este clon chino?
http://www.dx.com/p/pp2000-obd-ii-scann ... mDMyK3g5LU
En concreto, me gustaría saber si es full chip o no. El interfaz es de 16 pins
Pego la información que dan sobre él:
- Color: Black + dark grey
- Plastic material housing
- Allows perform complete diagnostics of all from 1995 untill present models
- Performed via OBD-II connector (which is located near steering wheel) or via manufacturer-specific connector (only older cars, pre-2001)
- Supports all the functions like the original dealer diagnostic tool, with K-Line multiplexor, CAN-BUS interfaces and SAE J1850 bus (both PWM and VPW) interfaces
- Functions:
- Read identification: Displays complete identification of control unit, e.g. part number, software/hardware versión, manufacturer, etc...
- Read fault codes: Displays all stored and pending fault codes with complete description (e.g. "Rail pressure - too low pressure"). Program supports report printing or copy to clipboard
- Clear fault codes: Clears all stored fault codes and other diagnostic information
- Auto-scan (complete car scan/test): Detects all ECUs (electronic control units) installed in car and reads all diagnostic fault codes
- Measured values: Program displays live Data like Engine Speed, Battery voltage, Oxygen Sensor, Coolant Temperature, etc. Values can be displayed in graph, 9 values at once, or full listing (all measured values). Logging to file is also supported, which allows offline analysis
- Actuator test: Actuator test activates particular actuator (e.g. turn on fuel pump, lock/unlock wheel, lock/unlock doors, cut off fuel, etc..)
- Programming functions/adaptation: One of great importance in all vehicles because systems like engine control units, immobilizers, airbags, alarms, body control units, and some others, require you to perform reset or programming procedures after car repair is done, or even
- Package includes:
- 1 x Scanner diagnostic tool (120cm-cable)
- 1 x 9pin to USB cable (120cm)
- 1 x 9pin to USB cable (20cm)
- 1 x OBD II cable (100cm)
- 1 x 16pin to clip cable (135cm)
- 2 x Software CDs
Un saludo,
Roman
- Functions:
- Package includes:
- 2 x Software CDs
Un saludo,
Roman
