ElMonty, este es una parte del contenido del fichero dentro de la carpeta System Volume Information de mi Tarjeta Original:
#Hydra
ANY: /database/kN083EUx05t02.DB
ANY: /database/LABEL.DB
ANY: /database/RN831_litdata.DB
ANY: /database/RN831_v36b.gdb
ANY: /database/S_ZF1914_v1.DB
ANY: /database/hazardareas.lwd
!dbinfo0001
skip_db update
PPD XACDB=kN083EUx05t02.DB
RN831.ras
RN831.xah
RN831_0.ort
RN831_0.plz
RN831_0.poi
RN831_02_25.tlt
RN831_03_01.tlt
RN831_04_09.tlt
RN831_05_01.tlt
RN831_06_01.tlt
RN831_06_17.tlt
RN831_08_17.tlt
RN831_09_09.tlt
Etc,etc,. Todo esto esta dentro del fichero kN083EUx05t02.DB el fichero se puede extraer con la herramienta navfldb_tool.exe
También esta todo esto:
NAME=cidguard. DATE=2009/02/06_12-12-57_UTC HOST=OEHHOBRUEGGMANN. USER=OBrueggmann
Fatal: Could not write slog event
(GNU) 3.4.6
cidguard - Check the validity of SD/MMC cards containing navigation data.
Usage:
%C [-p path] [-M file] [-d delay] [-f path] [-D] [-e extension] [-n name]
[-H file]
Arguments:
-p path Path to check for navigation databases.
-M file Print debug output to file (default is stdout)
-d delay Delay is seconds after program start to wait before
performing checks.
-f path Path to a directory to store dropfiles in. Dropfiles signal
a certain state of the the CID validation process:
nonavdisc.cidguard // no navigation medium
invalidcid.cidguard // invalid card id
ioerror.cidguard // io error during check
confirmedok.cidguard // medium appears to be valid
eject.cidguard // medium was ejected
unknown.cidguard // unknown state; ignore.
It is recommended for the path to point towards a temporary
directory. If this option is not used, dropfiles won't be
created. In case Option -D is specified, the signaled status
won't go the 'eject' state as soon as the card is dismounted,
and will remain at 'invalidcid' until a new medium has been
detected by the cidguard utility.
-D Automatically dismount the device the navigation directory
resides on.
-e extension Only check files with the given extension. If this option and
option -n are not specified cidguard will take _all_ files
into account. The option can be used multiple times to specify
up to 256 extension definitions. Extension tests are case
insensitive.
-n name Only check files with the given name. If this option and
up to 256 name definitions.
-H file Load legacy hash table from a file. Use this to override built
in legacy hashes.
Example:
cidguard -p /fs/sd0/database -M /hbsystem/multicore/p -d 20
Once the process is running for 20 seconds, it will monitor the given path for
changes. As soon as an insert of a navigation database takes place, the program
will attempt to validate the SD-Card to see if its genuine. If the card is
found to be invalid, the mountpoint the path is residing on will be dismounted.
This works as long as the underlying MMC/SD driver correctly supports the
interface as specified in dcmd_sim_mmcsd.h.NAME=cidguard
USER=OBrueggmann
PLABEL=PL_qnx_cidguard_09065A
QNX_versión=630
QNX_LABEL=RL_qnx_os_630SP2_PSP10_08073A
GCC_versión=3.4.6
CPU=arm
Se puede ver bastante información., solo pido que algún user suba su carpeta para poder mirarla.
Salu2.
